Hey I have installed IrRemote in my 3650 but i m unable to use that software can any one tell me how to cinfigure this software and how will it work with my LG Tv.
Thanks 😎
Thanks 😎
Okay it worked for a phillips magnavox for me but I had to hold it at a funny angle and it only worked for within about a foot.
I have taken some screen shots and uploaded them. Hope this helps.
First you find a open device and highlight it. Then click the circle button in.
A menu should open up and scroll down untill you find LG. Click on LG.
Another menu should open up and you should choose TV.
Then it should work and your screen should look like this. If it doesn't work try holding the phone at different angles. If it still doesn't work then I can't help you.
TheTooth wrote:Okay it worked for a phillips magnavox for me but I had to hold it at a funny angle and it only worked for within about a foot.I have taken some screen shots and uploaded them. Hope this helps.
Well thanks for ur help I have tried all the things but r not working for me may be no for 3650 or may be with the LG .... 😎
Thanks anyways
sorry I couldn't be of much help. I just got the program myself. If anyone knows of a website detailing instructions to programing the User defined device that might help solve this as well as future problems.
