Nokia 6260 and AT&T
5 replies · 2,829 views · Started 25 December 2004
I just recently purchased a Nokia 6260 (Black 😃) and I'm trying to set up the browser and other systems to work on AT&T's mMode. Unfortunately (and obviously), the OTA system for AT&T does not list the 6260. I tried choosing the 6620 instead, but although the message was recieved and the settings supposedly entered, I could not access the web. If someone could please point me to a method that will work for my phone, it would be greatly apprecaited. Or even list the required settings so I may enter them manually.
Thanks.
hey evverbuddy, alot of people from what ive seen, seem to be having problems with this so ill try and keep it breif to save from bein a pain in the ass
why is it that the software nokia hav provided with my 6260, wont recognise it??
ive been tryin for ages to get the PC suite to find my 6260 and my patience is wearing thin, i dont hav an ir or bt adaptor so im using the DK-wotsit-2 usb cable
the help files with the software might aswell not be there so is there anychance someone out ther in cyberspace can help plz
cheers in advance
Hard to say, with so little details about your problems. All I can suggest is to ge the latest PC Suite version (6.41.6) from http://www.nokia.com/pcsuite
Uninstall the old one (I think if you install the new one, it will first uninstall the old one), install the new version and then connect the phone with the DKU-2 cable. Then wait for Plug & Pray to discover a bunch of devices/interfaces (5 or 6 of them; let Plug & Pray look & find all of them, one by one). When Plug & Pray announced that "Your hardware is ready for use", then launch PC Suite.
