How can i change the themes in my SendoX, i already unstales some themes *.SIS, but i don�t know how to change't ?!
Can i play Mp3 as a ringtone, how can i do it?
pac-men wrote:How can i change the themes in my SendoX, i already unstales some themes *.SIS, but i don�t know how to change't ?!Can i play Mp3 as a ringtone, how can i do it?
You should really check the forum first before you ask questions read about and you will find out how to change and add your themes.
Also check the sendo website!
OK tell us where to find information on using mp3's as ringtones on this forum is then smart ar5e!!! I looked and cant find it. 😮
MAJ25 wrote:OK tell us where to find information on using mp3's as ringtones on this forum is then smart ar5e!!! I looked and cant find it. 😮
It won't work as an MP3, as the phone doesn't support MP3 being used as a ringtone format!
The file HAS to be a wav file. If it opens in recorder then it is a wav and can be used. If it opens in MP3 player, then it is an MP3 and can't be used!
Use dBpowerAMP Music Converter (free) and convert the mp3 to a IMA ADPCM wav file (play around with settings for balance of quality, size etc) and then send or up the SendoX software to save it to C:/NOKIA/SOUNDS/DIGITAL and u can use it as a ringtone - i've had one or 2 that wont work when someone rings u - but in the main it works fine.
Themes - profiles/general/personalise and then change it - as long as the .sis file has been installed.
No - themes get changed in Tools > Settings > Display, not in Profiles!
