Games are not beging discovered
5 replies · 1,954 views · Started 26 December 2004
After pasteing game files into my 64-MB MMC, some games does not appear in main menu. Reset helps - but only for a while, because if phone is forced to check games again (for example, after closing music player), they does not appear. The same games pasted into 128-MB MMC does appear and makes no problems. What can be the cause?
Regards -- Spook.
Ill assume you are talking about game demos, but some brands of cards won't work with the gage, it seems to be a bit picky on stuff like that.
merther02 wrote:Ill assume you are talking about game demos, but some brands of cards won't work with the gage, it seems to be a bit picky on stuff like that.
u just have to make the system folder to unhidden n unreadonly if u know what i mean
That's at least strange, because some games does work and some - doesn't. Card is read without any problems and I can open any file with FExplorer - even start "hidden" games! I think, that problem is in game/phone software, but I don't know Symbian well, so I'm not able to check it out.
Regards -- Spook.
funky_saggi wrote:u just have to make the system folder to unhidden n unreadonly if u know what i mean
I do know, but that I've done it already. It didn't worked 😞 (games didn't appeared)
Regards -- Spook.
