Psiloc e-File Manager..
3 replies · 1,822 views · Started 18 December 2002
I tried to copy contacts.cdb file. I couldn�t succeed. I tried many other applications, than I saw e-file Manager. with E-file manager it is possible : - Copying and Sending locked files ? an automatic function that allows you to copy and send any system file. according to Psiloc.
Even with e-file I couldn�t copy contacts.cdb.
The size of my contacts database is around 470KB.
Would you help me on this please.
If you would have done a search, you would have found out that you cant
do that. because the .cdb is in use by system _all_ the time, so it cant be
copied or anything.
Sorry.
there must be a way to do that. if I can copy while making a backup via PC Suite, it means it is possible to copy contacts file.
[quote="mrkin"]there must be a way to do that. if I can copy while making a backup via PC Suite, it means it is possible to copy contacts file.[/quote]
Well,Backup with Pc Suite should do the trick.Pc Suite backups everything except java apps.
