Hey Pals,
For god's sake, someone please tell me, where is Bluetooth Folder present physically on nokia phones... I mean, If I receive any stuff from Bluetooth connection, where does it get stored (in which folder).. I know, I can see those bluetooth stuff in my inbox folder, but i guess, its just references to the files, which should be present physically somewhere on C,D, or E...in some folder... and I want to know the location of that folder..
Let me tell u, what I need to do.. My friend has lots of nice SMS on his nokia7610, and I wanted those SMS via Bluetooth.. So I opened, FileMan, went to Mailbox folder, selected all those SMS, and sent it to me via Bluetooth.. Now I see those stuff in my inbox, files named 001001f, 0010008f, some thing like this...and If i try to open them, I get the error message "unknown message format"...so I realized, I should put all these SMS to E:\System\Mail folder, in order to read them...But there is no option for moving these files to physical FOLDERs other than User Created mail folders on inbox...so I need real location of Bluetooth files stored folder...Please tell me, if anybody knows about it....Thanks in Advance..
Where is BlueTooth Folder?
The stuff you get by Bluetooth is always stored at your mailbox just like SMS's and must be shown in your inbox.
can16358p wrote:The stuff you get by Bluetooth is always stored at your mailbox just like SMS's and must be shown in your inbox.
I think he already knew this... he is asking where they are in the file system...
UA
It is somewhere in these fodlers start with 001001 (something like that), usually in first one.
But you can't know where exactly it is, you'll need to find.
There is a Freeware program called Forward available here
http://www.compsoc.man.ac.uk/~ashley/
Which allows you to copy .sis plus any other files from your mailbox to anywhere on your phone including the memory card.
Highlight the file you want to save and then select Options/Copy File
You need to type in the path to the memory card for example....
E:\Documents
This will save all your .sis files in the documents folder on your memory card.
You have to copy files one by one though, this works fine for me on my 6630 so you should work for you too...
Hope this helps
Certainly beats searching through all those mail folders
Thanks Buddies for giving attention to my query.. I will try FORWARD, lets see if it can help me out ....
In my N82 I found a received file in:
c:\private\1000484b\Mail2\0001001_S\8\00100008_F\
This folder is not accessible without the right capabilities.
