i can't connect my pc suite to my phone,
im using a bluetooth adapter and a windows xp os,
can anyone pls tell me what to do,
i use the software that comes with the
bluetooth adapter to transfer files from my pc to my phone but i can't
transfer files from my phone to my pc (image files),
help,,,,,...... :cry:
Can you describe more in detail by what you mean you are not able to transfer images to PC. When you say send via bluetooth what happens ??
Seems to me that this is the registry problem!
there is a thread in this foru mthat has a fix for this!
try searching the forum for "phone to pc bluetooth" or something!
thanks for the reply,
im trying to send my pic. taken by my phone to my pc,
then i select the pic.
then option,
then send,
then send via bluetooth,
then my phone start to seacrh for a paired device (my pc),
then ill select my pc from the list,
then it will attempt to send the image,
then it will say transefer failed!
i just want to transfer my pic. from my phone to my pc, thats all,
i want to use the pc suite but i cant configure it,
if it's a registry problem, how do i fix it?
and could any one tell me what's the restart or reset code,
Here is the link for your answer!
http://www.allabouter6.com/phpBB2/viewtopic.php?t=3075
I would advise you to firstly go throuth the forum before asking! There is a lot of info packed in this one! However every question you have is welcome of course and we are happy to assist you!
As for the reset code it is *#7370#
NOTE: This will erase all your data, and this wont solve your problem with bluetooth 😊
hey thanks for te reply, i have not tried it yet, i'll try it when i get back,
thanks..... 😃
