I use the sreen saver application, and now, without made anything the digital clock does not appear!! It is active, but the screen saver that i see is the original from nokia!!!! Anybody knows what can be done to fix this?
Screensaver Apliccation not work properly!!
Have you tried re-installing the application?
Most probably, sleep mode is active. If I remember correctly it defaults to 1 hour. So after one hour, your good old Nokia screen saver takes over. This is done to decrease battery drain (anolog clock drains faster!)
Hello again. I�ve unistalled the screen saver program, but my screen saver is not the default one with the hours and date. I have a bar that says nokia!!!!!!!! How can i put the default one?? The program was removed from the phone and still causing problems
i'm guessing you have the text screensavwer active (it's default is 'Nokia'😉, try -
Tools -> Settings -> Phone -> Display -> Screen saver
then select 'Date and time'?
sorry if you already know this.
try to change your screensaver in the Tools -- Setting -- Phone -- Display -- Screen Saver -- Set to "Date and Time" not "Text"
try to save it
i countered the same problem. i got stuck in that defult nokia screen saver even i re-installed the program many times. Now, i cant see any of my slide show which i saved i dunno its from the version not complete or my mobile but it was working fine. Also, how can i run this program screen saver agian because this nokia saver is sucks . help me guys
