Bluetooth Unable to Connect Using Windows XP SP 2
2 replies · 4,797 views · Started 28 December 2004
Hello,
I'm using my 7650 phone communicate with my windows XP PC before and don't have any problem. I'm using Billionton Class 1USB bluetooth adapter.
Last week, I'm update my windows xp pro to windows xp pro Service Pack 2 with new security for bluetooth. I can sent my file from PC to my phone and my phone found my PC while paired device using my 7650 phone. But when I try to connect, the message "unable to connect" displayed. I'm already update my bluetooth configuration at my PC to "alow another device connected".
Anybody can help me to solve this problem?
Thank for advance.
I have the same problem with my Sitecom Bluetooth USB Adapter CN-500. I also can send files from my computer to my Nokia 7650, but not from my 7650 to my computer. It also displays "Kan geen verbinding leggen" (dutch) Cannot connect. And all becuase of Windows XP Service Pack 2.
I hope anyone can help me (us) because it's very annoying.
Tnx allready
kamilz wrote:Hello,
Thank for advance.
Have you checked to see if your device drivers were replaced by the native Bluetooth drivers of Win XP SP2? If they've changed, you'll need to "update drivers" back to the original ....
The Windows stack doesn't support OBEX, so you can't send files from Windows to a phone -- if it's working, then something strange has changed indeed (which means your drivers are partially working) .... if this is the case, make sure the security firewall isn't blocking anything .... make sure the yourbtdrivers.exe is free reign ....
