P900 Bluetooth & Infrared Issues
2 replies · 2,227 views · Started 28 December 2004
Hi All,
For some reason whenever I turn on the bluetooh or infrared connectivity option I can not turn them off after few minutes of usage. I go to connection and turn them off individually but with no use. Also my battery ends up getting drained so quickly (in two hours).
I have tried restarting the phone but with no use, the only option was to keep the phone off for an hour or so and everything would return back to normal!!
Any ideas???
Thanks a lot
oy! mate, ive got the same problem...I don't know how to turn my bluetooth off...First, ive got a problem on how to turn it on and after several attempts of restarting and removing the battery, i finally got to turn the bluetooth on. And then suddenly, while i was transferring files to my other phone, the bluetooth did'nt work...so i tried to turn the bluetooth off, then, it did'nt. I tried to restart and remove the battery but ive got no luck. Can you guys help us out? i really really REALLY need to know how to fix this problem. argh.
...and one more thing. its so hard to connect to the cable. after several attempts to restart and remove the battery, i can finally connect to the pc...BUT it's such a hassle to do that....and I believe theres a problem in my phone...can anyone help? thanks guys. =)
I have the same problem, and nothing seems to fix it. Does anyone have a solution, or can I assume that there is in fact a hardware fault... I've reset the phone and that didn't fix it, so it does seem like the most likely cause is something technical...
It's very frustrating though.....
anyone?
