E.mail POP3/SSL with Domino server
1 replies · 4,543 views · Started 28 December 2004
I m' using a Lotus Domino server (vers 6.5). The port SMTP, POP3 with SSL is open.
When i try to connect my P910 with the Mail program provide with the phone, i have on the server a error : POP3 server : SSL Handshake failure : Network io error.
When i try with another program on the P910 (ProfiMail) it's ok
When i try with other PDA (Treo 600 is ok).
On the domino server, Options setting for SSL
V2.0 Only
V3.0 handshake
V3.0 only
V3.0 With V2.0 Handshake
Negotiated
I have also SSL keyFile Name with Keyfile.kyr.
It's important because we try to open this solution to a lot of people in the company and we need to give them OS who are avalaible with our configuration ...
Is there anywhone who have a idea ?
Hi.
I know this post is a little old, but I thought I would add my experience...
I'm using Domino R5 and have experienced the exact same problem using IMAP or POP3 over SSL on a P910i.
Interesting that I can use a Treo600 (with Snappermail), SPVC500 (default mail client), SPV2000 (WebIS Mail client) successfully, however the P910i is the only client I've had issues with so far...
...if anyone else has any thoughts on the matter, I'd be interested to hear them.
Thanks,
S.
