Coping MMC files
2 replies · 1,969 views · Started 28 December 2004
I did a search, but i didnt know the right keyword to look for this.
I want to put all the files on my current MMC to my new one, but PC suite isn't finding my bluetooth connection, so I can't use that to get them, and there's no software that came with the bluetooth usb adapter to let me do this, so is it possible to put the files from the MMC to the phone?
duffers wrote:I did a search, but i didnt know the right keyword to look for this.
mm I quess the easiest way is surly: buy a card reader for your PC (costs about 9�) and copy your files directly on your computer!
otherwise: Try searching for Mrouter or something like this, so that you can solve the problem with yout BT-connection!
oh, i didnt think they could copy files from the phone to the pc, thats great help, thanks alot. Haven't a clue with the Mrouter though, don't know exactly what to do to find my phone.
