SMS Delivery Reports
8 replies · 6,378 views · Started 28 December 2004
I've just noticed that I am not receiving SMS delivery reports even thuogh the settings for this are correctly selecting.
Has anyone else experienced this?
I receive the report just after sending the sms, but you can't see it after or even save it (but dp you really nedd to save it?).
Jass wrote:I've just noticed that I am not receiving SMS delivery reports even thuogh the settings for this are correctly selecting.
Reports for SMS Delivery Will cost u like a SMS : .E.G If u send a SMS and u receive the report u'll spend the money for the SMS + the money for the report so u'll spend the double : it will be like if u send 2 SMS
in india, delivery reports are free. on my phone the delivery reports are "ON". if ur sending a sms with the cover open, as soon as u send the sms close teh cover & then see the front screen, you will see the MESSAGE SENT screen & then soon after u will see the DELIVERED screen, but unline other series 40 phones, it does not come in the inbox.
i had loved the nokia 9110's delivery report system. it used to stay on the screen inside & only when u press ok would it go away, it used to also let u know the time & date of the delivered sms.
that was one good function i missed in the 9210 as wel as the 9500 now.
Yip its in the log view
ctrl+shift+L in messaging (well actualy from most windows)
😊 Delivery reports on mtn SA are also free 😊
Only thing it does not tell you the time it was delivered... well not that i know off.
I find it hard to believe that any operator would actually charge for the delivery reports anywhere (except perhaps in the U.S., where they charge the one who answer/receives a call, too).
Duh. Is there still no way for Nokia 9300 to either:
- play a sound with the delivery report,
- the delivery report to be stored as an SMS?
It becomes tiresome for me when sending an important message to watch the log for the "Delivered" status. Perhaps there is a third party application which would enhance this function?
