hey all.. on my 9210i .. on the label under the battery.. do u have 9210i written on the label?
it isn't on mine..
duh!
Check your RAE version. It will give you a clue.
what's this ? how can i access it?
i wanna be sure that it's 9210i not 9210
an btw.. what is the Application memory? 16 MB .. what about user memory?
*#0000* RAE Ver.
It must be bigger than 4.14
You have 4 Mb on device and 16Mb up to 128 on Memory.
In control panel-extras check memory, it will give you infos about your device memory
For a 9210i, *#0000# entered on the outside keyboard gives me:
V 05.34
31-05-02
RAE-5
You should get something similar. If the top line starts with
V 03.xx or
V 04.xx
then you've got a 9210 or 9210e.
The quickest check is probably the colour of the buttons on the outside :P
Black/dark grey: 9210 classic
Silver: 9210i
