Hi all!
I have tried the trial version of Philips Camcorder Pro for my 6260 and it's just amazing! It improves a lot the in-built nokia's video recorder.
After searching in this web, I still have one question: am I only available to record at 7,5 fps while audio is on and format is QCIF (and quality Pro)? Is this a limitation of the 6260'2 harware or a limitation of the trial version?
It would be impressive to make videos in QCIF and 15 fps and the audio On...
Thanx in advance!
Freeman wrote:Hi all!I have tried the trial version of Philips Camcorder Pro for my 6260 and it's just amazing! It improves a lot the in-built nokia's video recorder.
Thanx in advance!
Nobody has tried this app in his/her 6260 🙄 ?
where did you find the trial?
i would like to try it.
Hi Freeman,
I am actually using the Camcoder Pro app on my 6260.
Allthough it's the trial version, without the trial limitations, I'm also only able to make record in 7.5 fps in QCIF mode.
But when you lower the resollution (screenwidth I mean), it's possible to record in 15 fps. So it's either small screen or low framerate... :frown:
I hope somebody who actually bought the application can also share his / her experiences...
Thanks...
rvdgeer wrote:Hi Freeman,I am actually using the Camcoder Pro app on my 6260.
Thanks...
Mmmm... what a pitty! I hoped that it were only a trial limitation :frown: .
Ok, thanx for your answer rvdgeer :icon4:
