Wich One Should I Choose ,"P900" Vs "6630 Nokia" ?
P900 Or 6630 ??
First of all, I think the decision between the P910 and 6630:
Pro's 6630:
1,3mp camera
UMTS/3G
Pro's P910:
Multiple input options (including a keyboard)
Furthermore it is important to realise if you like a touchscreen (more versatile) or one-hand usage (easier)
Dv1726 wrote:Wich One Should I Choose ,"P900" Vs "6630 Nokia" ?
I've got them both now.
They are two different kind of phone.
The P900 is a "smartphone" not just a phone, but a kind of palm or pocketPC (as u better like).
The Nokia 6630 is a 3G phone, usefoul to videophoneing and to use as a normal cellphone.
So I think u have to chose with regards to your needs...
P900/910 are considered by most reviews I've read as the undisputed kings of smartphones.
Unless you are buying an external keyboard bare in mind that writing long texts with the keypad is complicated and annoying (while the P900 has the virtual keyboard and handwriting recognition, and P910 even has a built-in keyboard). But then again, try using virtual keyboard on the bus or while walking - a very tough task.
If games are important to you - go for the 6630. The P900/910 don't have much to offer in that realm except a Lemmings game and a rally game which is annoying to play.
Looks is a matter of personal taste, and I think the P900 is the best looking one of the three (6630 and P910).
