6600 Apps on 7610?
2 replies · 1,895 views · Started 29 December 2004
I have recently upgraded from my 6600 to a 7610. Can I install the same applications on the 7610 that I used on my 6600?
Thanks for any help.
Most should work as-is. You might check for newer versions from the developer(s) in question.
AndyCr15 wrote:I have recently upgraded from my 6600 to a 7610. Can I install the same applications on the 7610 that I used on my 6600?
Ive recenty upgraded to a 7610 & all my 6600 Apps worked fine these inc
Psiloc worldclock
FEXplorer
UltraMp3
