Complete Syncing with outlook
2 replies · 3,771 views · Started 30 December 2004
Has anyone tired to completely sync their outlook with the 6630? PC suite does not bring over the notes/message box of each apppointment that allows for additional information pertaining to the appointment. Has anyone been successfully in getting this information to sync with the phone? Better yet does anyone make any software that syncs all fields of the outlook appointment with the 6630 phone? When I had my ericcson t39 it would pick up most of the notes associated with the meeting/appointment. This is the only drawback that I have come across with this symbian based phone. Someone has to have noticed this deficiency in the syncing software.
It is a limitation, but rather due to a lack of space/fields for appointments in the Calendar app to match all that's possible in Outlook (or Lotus Organizer/Notes, which also is on the supported list of apps to synch with using PC Suite). Until such a change is done on the Symbian/Series 60 -side for the Calendar app, there's not much that can be done.
N/A wrote:It is a limitation, but rather due to a lack of space/fields for appointments in the Calendar app to match all that's possible in Outlook (or Lotus Organizer/Notes, which also is on the supported list of apps to synch with using PC Suite). Until such a change is done on the Symbian/Series 60 -side for the Calendar app, there's not much that can be done.
So basically it sounds like Nokia failed to design this in with the 60 series. Do you think the communicators 9500 and 9300 are subjected to the same limitations? I guess this would be one reason why PDA phone may be more appropriate for an all in one device.
