Bemused apple server
1 replies · 2,087 views · Started 30 December 2004
There are three great programs which will allow you to control your Apple from your phone/PDA over Bluetooth.
Salling Clicker, available at http://homepage.mac.com/jonassalling/Shareware/Clicker/, is a simply excellent $19.95 shareware program which integrates with iTunes as well as a lot of other applications, including Powerpoint. There are a lot of plugins available on the net. Take a look at VersionTracker or MacUpdate for them. Jonas Salling, the author, has just added Sendo X support to version 2.2.
If you don't want to spend $19.95, there are two free versions which, although slightly less capable, are highly rated:
- Romeo: http://www.irowan.com/romeo/
- Bluecommand: http://www.salvatorescandurra.com/bluecommand/
Since I've used Salling Clicker for some time, I've not tried either of the free alternatives. A friend is using Romeo on his T610 and is very happy with it.
Hope that helps!
Cheers,
David
