hello, i'm new to this forum as well as to S60 Smartphones - I recently bought both a N6260 and a N3650(second-hand,great deal!) and the 3650 doesn't support S60 themes! And that sh*t's just annoying! When i tried to install a theme file (.sis), the n3650 replied: "Please install Series 60 skin support" or stuff like that. So i ask you: CAN i install it, HOW, and WHERE can i get it?
I should mention that software like SmartLauncher doesn't cut it for me 😊
THANKS a LOT!
Series 60 Skin Support.sis
No, there is no way whatsoever to get Series 60 Themes support for your 3650.
:icon14:
Hubba_Bub wrote:hello, i'm new to this forum as well as to S60 Smartphones - I recently bought both a N6260 and a N3650(second-hand,great deal!) and the 3650 doesn't support S60 themes! And that sh*t's just annoying! When i tried to install a theme file (.sis), the n3650 replied: "Please install Series 60 skin support" or stuff like that. So i ask you: CAN i install it, HOW, and WHERE can i get it?
THANKS a LOT!
I have file but must have more file is 1 teorie how themes but I don't know this work :
teorie this there but must friends in phone n6600 to download file
1take psln file in z:system/app/psln(folder)
2) take psln.dat in z: system/data/psln.dat
3) take psln00 in z: system/libs/psln00.dll
4) series60skins suport in z:system/instal/
5) the skin folder in z:system/skins
next
1copy/paste psln(folder) to c:\system\apps
2.copy/paste psln.dat to c:\system\data
3.copy/paste psln00.dll to c:system\libs
4.copy/paste S60SkinSupport.sis to C:\SYSTEM\INSTALL
5.copy/paste skins(folder) to c:\system
I have only 1 file S60SkinSupport.sis
Gfhfj
hi i have recently got a Nokia 6600. But i dont have series 60 skin support. hence i cant add new themes to my mobile. can anyone plz tell me how can i get series 60 skin support.sis
The 6600 supports S60 Themes without installing anything, except the S60 Theme.
However, note that newer format theme files for newer phones (like the N91) don't work on the 6600.
Get themes for the 6600 from, e.g., http://www.symbianthemes.com
where to D/L Series 60 Scaleable skin support.sis???
Pls advise.
Tks
Nowhere. There is no such thing to download/install on older phones. It is a feature of S60 2nd Edition Feature Pack 3 (S60 2.8) based phones and later, and cannot be "retrofitted" to older phones with any kind of .sis file.
where can d/l S60 2nd Edition Feature Pack 3 (S60 2.8) ???
You can't download that anywhere, either. You can get it when you buy a phone that has it built-in, such as the N70, N72 or N90.
ok yes ay
THANKS a LOT!
thancks
