hi all
can please give me c++ source for simple class
that implement c++ symbian s60 file reading/writing
i need this for use in my app data managment
i have try to implemnt it by myself but
have stund with problem in creting file on memory card were i have install my app
thanks a lot
shade
thanks to gods
i have solve the problem after reading some examples
here is my code that can read and write data to data file that can be located in app installation path i think it's may be useful to newbie�s
TFileName appFullName = CEikonEnv::Static()->EikAppUi()->Application()->AppFullName();
TParse parse;
//On WINS the application is on the z drive
#ifdef __WINS__
parse.Set(_L("c:"😉, &appFullName, NULL);
#else
parse.Set( appFullName, NULL, NULL);
#endif
TFileName iPath; // contains application's path
iPath = parse.DriveAndPath();
TFileName e3dlog_filename;
e3dlog_filename.Copy(iPath);
e3dlog_filename.Append(_L("e3dlog.txt"😉);
RFs fsSession;
RFile file;
TFileText txt_file;
User::LeaveIfError(fsSession.Connect());
TInt err=file.Open(fsSession,e3dlog_filename,EFileStreamText|EFileWrite|EFileShareAny);
if (err==KErrNotFound) // file does not exist - create it
err=file.Create(fsSession,e3dlog_filename,EFileStreamText|EFileWrite|EFileShareAny);
TBuf8<256> data;
data.Copy(e3dlog_filename);
file.Write(data);//Write seeks to end of file
fsSession.Close();
