HELP NEEDED - 7650 Dead
3 replies · 2,230 views · Started 31 December 2004
HELP!!!
I had my phone on the floor, and i knocked it as i turned around... didn't think anything of it, no beep or anything...
anyways, looked at my phone and it's tellin me to insert the memory card... sure, memory card musta got knocked a little perhaps... remove, reinsert.. nope... try again.. still nope..
so, maybe the phone needs a reboot... power down.... and can't power back up..
i stuck it in the charger, and the little charging symbol that will show up when the phone is off but charging doesn't show up either...
HELP!!!
btw, forgot to mention.. there's still plenty of memory left ... so it's not the memory bug
whoops~~~ seems i made a big typo... not memory card.... SIM CARD...
might be a switch problem
try reassebbling ur fone
its easy check the on off switch properly
might do it!!!
