1 GB MMC on 3650
2 replies · 2,003 views · Started 01 January 2005
I'm thinking about putting a 1 gig MMC on my 3650. I know that nothing above 128MB is "supported" by Nokia, but I just wonder if there is anyone here who is doing it, or actually knows anyone who is? If so, what brands would you suggest?
I've used a 1 GB MMC in my 3650, only thing was that it only had a capacity of 980 MB in the phone (checked with the MMC App in the phone).
The brand I've used is something called Hexon. I've also heard stories that it depends upon each model if a 128 MB higher MMC will work or not, so if you want to know if the phone works with a 1 GB MMC, you should ask your dealer you want to see if it works in your phone, and test it. (That's what I did).
Thanks. I'm guessing it depends on two things: the firmware of the phone, and the card itself. Supposedly MobyMemory (I think that's what they're called) offers cards that have been tested on the 3650, so I'm thinking that might be my best bet.
