IrDA Problem
8 replies · 4,175 views · Started 01 January 2005
hi,
just wondering, is there anyone experiencing problem using the infrared of 9500? i always experience crash when i tried to transfer file from my laptop to 9500. it stops responding and then reboot itself. please help, my firmware is 4.44 and is made by nokia.
thanks.
I've transferred several things from my laptop to the 9500 without problems. I have the same firmware (we all do at the moment). So not sure what the problem is or can be
Delta737 wrote:I've transferred several things from my laptop to the 9500 without problems. I have the same firmware (we all do at the moment). So not sure what the problem is or can be
r u transfering a large size file? in my case and my cousin's, the size is more than 500 kb, and from 10 attempts, it failed about 8-9 times. will it be because of the filesize?
cnn_08 wrote:hi,
thanks.
I had the same problem, It works with all IrDs except my build in IrD in the laptop
an ideas?
Delta737 wrote:The files I tried were small. I usually transfer bigger files by BT or using a cardreader
i have bt, and card reader, its just when u travel, u wouldnt bring all of your gadgets with u. it just happen when i travel and i need to transfer some documents to read on the way, and it just would do.. so...
karym6 wrote:Have you made sure that your IR speed is set to 115.2kbps on the laptop?
i will try that, since i found my laptop's settings is on 4 mbps. thanks.
i have made the speed to 115.2 kbps, still the same proble, it even restarts when i try to connect the phone to the laptop. i havent even transfer anything to the phone yet
