hi,
last nite i tried to open a word document, but it refuses to display the table as it says there is no table function. is there anything i can do to overcome this problem? thanks
Word update
same problem here. I read in help-file that I should select the table and press enter. But if I do so, then I'm asked to confirm deleting the object...
Convert Word files to Mobipocket .prc format. Mobipocket can handle tables, and .prc files are much smaller and load much faster than converting from Word. You cannot edit .prc files, only read & make annotations & bookmarks.
maybe a stupid question: how do I do that?
samka wrote:maybe a stupid question: how do I do that?
You just need to install the Mobipocket Office Companion (from www.mobipocket.com).
It converts Word, Excel, PowerPoint documents and Outlook mailbox (mails, contacts, calendar, tasks) to read them on your PDA.
