importing midi
1 replies · 2,166 views · Started 01 January 2005
Hey ! ....
How do u imporet midi files ?? ... i downloaded a few midi files ... my ngage detects it but i still dont know a way to play them or use them as ringtones .. please
help me out !
The way I do it with my Original N-Gage is to plug in the USB lead into the back of o PC.
Forget PC Suite (Rubbish!).
The PC will detect the memory card and will display it as Disk in My Computer.
If your midi files are on your PC or wherever they are, you should move them to the folder on the N-gage memory card directory (Sounds/Digital).
Once your phone is unplugged, you can find the midi files in the Recorder Application.
If you want to play them in PlayList format, you will need to download some sort of software like MMPlayer.
Good luck.
Any more problems, either reply through forum
or to my e-mail:
[email][email protected][/email]
