WiFi on A925
15 replies · 4,564 views · Started 02 January 2005
Delta737 wrote:No, not possible. Only Symbian phone with wifi is the Nokia 9500
is there any way to install some hardware on it to use it?
perper wrote:I see a web site, http://www.i2020.co.uk/p1128/sandisk_connect_wi-fi_sd_card.htm, saying the 256 Wi-Fi SD Card is compatible with A925 but no details at all :con? . I have no way to borrow one to try but I really hope it can support Wi-Fi; otherwise, we need to use the expensive GPRS. 😎
Good Luck
You will probably be able to access the memory on the card, but not the WiFi part, as there are no drivers and the A925 is not SDIO capable.
What about the A920 flashed to A925? I thought that there was a way to get WiFi, what is what I was told about the phone, but it could have been a bunch of BS. As well, does anyone know anything about getting an internet connection and text messaging info for an A920 flashed to A925 on a Rogers Wireless connection in Canada?
bighauns wrote:What about the A920 flashed to A925? I thought that there was a way to get WiFi, what is what I was told about the phone, but it could have been a bunch of BS. As well, does anyone know anything about getting an internet connection and text messaging info for an A920 flashed to A925 on a Rogers Wireless connection in Canada?
you mean mms?
an a920 flashed to a925 is the same as an a925 😃
fone crzy wrote:is there a way to use wifi on the motorola a925?
Yes you can. I have a wireless SD card I bought off of eBay and it works great.
Smoki wrote:Yes you can. I have a wireless SD card I bought off of eBay and it works great.
Can you tell me what WiFi SD card you have that works with your A925?
David
hi, any news for this problem?
please can you post "how" you have an A925 with WiFi function?
thanks
