Hi.. im using a nokia 7610 and lately its been acting weird..
the first problem is whenever someone send me a msg... the phone wont play the msg tone... the phone wont even light up to notify.. the only sign of receivings msg im getting is tat theres a small msg icon on the top right of the screen... im sure theres no problem with the tone and when somebody calls.. the phone will ring as it normally should..
the second problem is usually when someone miss calls or msg... normally the phone in standby mode will show the msg "1 miss call" .. or "1 msg received"... and those msgs wont appear too.. its really wierd.. did i mess up with the settings? or is there a problem with my phone... help me pls... thanks in advance...
strange indeed,has this only been a recent problem for you or has it been doing this since you bought it.If only recent check setting's to make sure all is correct,also maybe new app or game or theme could have made problem,but my best advice to you would be simply to get your phone checked out by dealer. 😊
badboythemer wrote:strange indeed,has this only been a recent problem for you or has it been doing this since you bought it.If only recent check setting's to make sure all is correct,also maybe new app or game or theme could have made problem,but my best advice to you would be simply to get your phone checked out by dealer. 😊
thanks for replying.. it has only started to happen yesterday... and im quite sure theres nothing wrong with the settings.. is there even a setting that can disable those?...
Check your profile settings .. It should be related that ...
this happens with me too but only after i experience some error like 'App closd ncnlist or App closd ... blah blah' i restart the phone and everything goes back to normal, by the way i've been trying out fonts lately and that requires rebooting the phone. is rebooting the phone too often harmful for the battery or something?
sigh.. i tried rebooting the phone and setting the profiles but it still doesn't work.. guess i have no choice but to take it to the nokia service centre then.. thanks for all ur helps though.. T__T
your welcome 😃 though sorry that you didn't find answer
