SDIO support
7 replies · 2,020 views · Started 02 January 2005
fone crzy wrote:does the a925 have sdio support. i am on the newest firmware!
To the best of my knowledge: No.
Otherwise you'd think Motorola or 3 would advertise it as one of the main features, being able to use WiFi cards in it et al.
Or not. If you would only surf over wifi, 3 wouldn't make a lot of profit now would they. I'm not saying the A925 has SDIO (I don't know to be honest :redface: ), I'm just saying 3 wouldn't necessarily advertise with it...
Delta737 wrote:Or not. If you would only surf over wifi, 3 wouldn't make a lot of profit now would they. I'm not saying the A925 has SDIO (I don't know to be honest :redface: ), I'm just saying 3 wouldn't necessarily advertise with it...
Well, you can already do that with Bluetooth, which the A925 supports, so I don't quite see what they would have to gain by enabling BT in their later firmware for the A920, but not telling us about SDIO capabilities.
albatorsk wrote:Well, you can already do that with Bluetooth, which the A925 supports, so I don't quite see what they would have to gain by enabling BT in their later firmware for the A920, but not telling us about SDIO capabilities.
so the a925 does have sdio support?
