A potential fix for non starting phones
11 replies · 4,541 views · Started 03 January 2005
Hi all, I managed to render my phone unstartable recently, by trying to change the startup animations. My phone would say motorola 3g and just freeze when it should have played the motorola anim.
I was going to take it back but I was playing about after reading another post saying other motorola phones had a button that could be held down during startup, to perform some sort of reset boot.
Sure enough if you hold the triangle button down during boot my phone started allowing me to remove the offending animation files!!
hope this helps anyone!
zamv wrote:Hi all, I managed to render my phone unstartable recently, by trying to change the startup animations. My phone would say motorola 3g and just freeze when it should have played the motorola anim.
Hows about talking us thorugh how u removed the files then
I'd love to get rid of the startup animation for 3
You see.............im not 12 years old, Having my business phone play that *!%$ when it boots up is embarrassing
I agree, thats why i tried to get rid off them 😉
heres the link:
http://www.3g.co.uk/3GForum/archive/index.php/t-11538.html
So once again be warned, holding down the triangle button should start the phone again if it doesnt start, but I havnt done much testing with this. It's possible that u have to create 3 actual mp4 files, I just created 3 txt files and renamed them. who knows. Let me know if you get it working
But where are the originial startup files for the disco three + music located? How was it possible that creating a new folder in C:\documents\startup overrides the original files?
zamv wrote:great, it works.
thanks 😊
So, I created C:\Documents\startup, and copied the three files into it. But somehow, the "customerimage.mp4" file is being recognized as a "directory ".
I can't do anything to the file or its filename.
Any clues on this?
Thanks.
machmandp wrote:Hi all
I had no problem with the files i created but i have seen problems elsewhere
So i have put my files onto my server
www.machman.co.uk/a1000/startup.rar
Just extract the startup dir into the documents dir on the c drive and that should be it
Dean
dipshun wrote:So, I created C:\Documents\startup, and copied the three files into it. But somehow, the "customerimage.mp4" file is being recognized as a "directory ".
Any clues on this?
Thanks.
A simple step by step can be found at http://www.aussie3g.com/modules.php?name=Forums
goto a1000 section where you will find loads of handy hints.
Just now I read your thread. I created 3 txt files like I think you have done, and I renamed them (with mp4 extension). But my phone freezes in the motorola 3g logo. I tried holding down the triangle button when starting the phone but the phone remaines freezed! What am I doing wrong?
Can you help me please?!
zamv wrote:I agree, thats why i tried to get rid off them 😉
heres the link:
:icon14: :icon14: ok! don't know how but my motorola A1000 is back... everything is ok now 😊 😊 😊
hi !
the instructions i have found have said:
1: make a jpeg-file by taking a picture with the camera, then copy it to:
motostartup.mp4, hutchisson.mp4, motoshutdown.mp.4
2: make directory c:/documents/startup
3: move the 3 files there
you can even use an empty file
