I picked up a nice WAV tone with about 500 Kb and selected it as my ringtone.
But when someone calls me the X plays about 5 seconds of the ringtone and then starts playing the alarm tone :con? .
Is it the size of the file that�s causing this? Any ideas?
I have a similar problem, though the phone plays the default Sendo_Ring after a couple of seconds. Trying to work out why, I have tried several different ringtones and while I have not been able to work out what is going on, the size of the ringtone seems to be nothing to do with it.
Cheers,
Dave
pedroabteixeira wrote:I picked up a nice WAV tone with about 500 Kb and selected it as my ringtone.
But when someone calls me the X plays about 5 seconds of the ringtone and then starts playing the alarm tone :con? .Is it the size of the file that�s causing this? Any ideas?
Trie to put the WAV file in the phone memory. I used to have a similar problem whem I used the MMC :icon4:
SENDO X :icon13: :con? 😮 :icon13: :icon13:
cfodesign wrote:Trie to put the WAV file in the phone memory. I used to have a similar problem whem I used the MMC :icon4: SENDO X :icon13: :con? 😮 :icon13: :icon13:
The WAV file is in the phone internal memory.
Thanks anyway.
This problem is not Sendo specific. Had the same issue with my 6600 with all
firmwares.
Putting the wav-file in the phone memory eliminates the problem for me at least.
I have a similar problem. I have several different ringtones on my phone which have been assigned to different people. But very occasionally it will revert to a default ring tone or the alarm tone if one of these contacts call me.
I have always found it works best if you convert the file to IMA ADPCM wave file using DBpowerAMP Music Converter which is free from http://www.dbpoweramp.com
i have always used dbpower to convert my ringtones to wav for my x and never had any problems
