Outlook Contact Settings
3 replies · 1,980 views · Started 18 October 2002
Could someone please tell me the settings they have in Outlook in order have your contacts on your phone as "First Name Last Name" rather than the default "Last Name First Name"
Thanks in advance
just download a program called "name swap" you can do a search for the threads for the software.
use the "file as" option in Outlook to show last name first name as the display option and then select that field for syncronisation with the 7650.
It works fine!
In your Outlook
Click on Tools -> Preferences tab -> click on "Contact Options..." button -> a popup will show.
You may want to change the Last name First name order.
Hope that's help 😉
