Volume is too loud
6 replies · 3,634 views · Started 03 January 2005
I have problem with volume of Java and S60 apps that I installed. Every sound in them are too loud. Is there any way to lower the volume? Only thing I've found is volume control for ringtones but how should I adjust volume with games and apps?
Thanks in advance.
-Eino
Eino Gr�n wrote:Hi,
Thanks in advance.
-Eino
check the game setting instead not the phone setting.
ICE SCREAM 4 u wrote:check the game setting instead not the phone setting.
Well, for most of games there's no setting for sound volume at all.
Eino Gr�n wrote:Well, for most of games there's no setting for sound volume at all.
It might not be written as "Sound volume" but it might be written as: Effects sound or music sound. 😃
By the way, what game are u playing?
And Nokia games that cane with phone don't have volume control, and volume in those games is very loud also. There really MUST be some setting some where :/
is the button located in the central panel and you can click left or right to adjust the volume, however, you can't while you are playing frozen bubble (coz I tried it on mine as well).
