Opera help (O2 genie sim)
1 replies · 2,435 views · Started 03 January 2005
Hey, I have got a sendo X, unlocked from Expansys, and so inserted the brand new O2 genie sim card (the one with 300 free texts on Pay and go) I had bought not long before and began to try all the applications. After setting up wap and finding that mms worked perfectly, I tried Opera and noticed that it wouldn't load up any address I put in and the only page I have ever seen in the program, after numerous hours of wait in total, has been the default sendo web page in the browser. :con?
I have tried: O2 Wap, O2 GPRS, O2 ISP, O2 GSM and others I made from advice I found on the net, but none of them have worked! I have used www.O2.co.uk and www.sendo.co.uk but all that comes up is connecting at the bottom of the screen which then disappears after a few seconds. If anyone has their sendo X on O2, preferably a genie sim could they please tell me how they got opera working and/or the settings they have got. Thanks for the help.
Genie customer services will be able to advise you if they support full internet access over GPRS and if so what their specific settings are
