maybe the simplest question : Themes
2 replies · 1,832 views · Started 04 January 2005
Hi all,
Could someone explain me very simply how to change the X themes.
I've already try to install *.sis files but no way.
Do I have to install a specific stuff to allow these kind of themes.
Let me know.
I don't know how far you have managed to get, but for me installing a new theme was very straightforward. I sent the .sis file over (using Bluetooth in my case), and when I read the message it asked me if I wanted to install it. I would expect the same thing using the PC link application.
But installing a theme is only half of the job. You also have to select the new theme before you can see it. From the main menu (use the application button to switch to it from the Now screen), choose Tools -> Settings -> Phone -> Display. The top option should be 'Theme', and the newly installed theme should now be in the list to choose from.
Sendo advise people to switch to another theme before trying to uninstall the current one.
