Hi!
Has anybody installed an operator logo successfully?
The procedure from the Nokia 6600 does not work (either via FExplorer, or manually).
Please help.
Brgds
Hi!
Please help.
Brgds
not sure if it works with the 6630 but try Opman software to change yr Op logo.
Changed my oplogo using fexplorer, no problems. got the latest version?
That's strange. I used FExplorer 1.11, and also tried it to install it manually to the directory. I used a BMP file and also a JPG file, which was converted to BMP by FExplorer.
What firmware do you have? I have 2.39.15.
I just found out that it works with a different network.
Network 05 shows the logo, but I use network 10.
I looks like that the filename can not handle network codes above 09.
brgds
Can anyone point me to a tutorial about op logos and how to change them? I'd like to know what type of files and what sizes can be used as logos....
UA
superj wrote:I just found out that it works with a different network.
Network 05 shows the logo, but I use network 10.I looks like that the filename can not handle network codes above 09.
brgds
3.45.110 firmware, 02/12/04
Orange UK, no idea what the network id is sorry
Orange UK's 2G network is 234-33. Orange UK 3G will be a 234 prefix, but may be a different suffix. If you download something like CellTrack or miniGPS, then it will be able to tell you the network ID.
