Problem with sorting my contact list
5 replies · 3,104 views · Started 04 January 2005
hello all,
I have a problem sorting my contact list by (firstname, lastname). I checked the use manual and it says I can click on "Contacts" then "Options" then "Settings"...however, I don't see the option "Settings", wondering if it would be a glitch of the software. Is anyone encountering the same problem? Please advise. :con?
after contacts, open up one of your contacts, and when it displays their name on top and their phone number(s), then go to options > edit. then you should be able to edit their phone number at this point. go to options > add detail. then you can add a first and last name, company, job title, etc.
unless you simply mean that you can't sort them the way you want to after having added a first and last name.
in which case... i can't help you, good luck!
bounceism wrote:after contacts, open up one of your contacts, and when it displays their name on top and their phone number(s), then go to options > edit. then you should be able to edit their phone number at this point. go to options > add detail. then you can add a first and last name, company, job title, etc.
IT IS THE CASE! :frown: I think it could be a software glitch....anyone else is encountering the same problem? Does anyone know how to fix this issue?? BTW....I am referring to my contact list on phone memory and when I click to my subscribe list, I do have the option to sort them by firstname......
I have this problem too. I couldn't find the "Settings" option in my contacts.
Still looking for the reasons why.
I am using N80 with software version 3.0617.0.6.
