Opera browser
10 replies · 2,550 views · Started 04 January 2005
Hello,
has anyone used the Opera browser successfully with the A1000? I installed the browser, but it didn't work.
dipshun wrote:Hello,
Opera is already installed afaik. Start the browser and point it to the web address
about:
It will show "Opera 7.50 for Symbian OS ("708"😉"
Hi, I had the same problem. It seemed to start and then, nothing happened. I think the problem is, that the pre- installed browser in the A1000 is an Opera browser.
You're right. Thanks. Now comes the next question:
1. can we change the startup homepage set by THREE?
2. Are there plugins that can be downloaded and installed onto the A1000?
Thanks!
dfraz wrote:Opera is already installed afaik. Start the browser and point it to the web address
about:
dipshun wrote:You're right. Thanks. Now comes the next question:
Thanks!
The "Three" network in the UK only lets you look at what they have, on their own site.
Really pathetic. It is not possible to go to the outside web, and the parameters of their access point can't be changed.
What type of plugins do you mean?
there are two plug-ins installed: Shockwave, and HutchPad Central Plugin.
I'm not sure whether you can install more plugins or not.
As for web access, I was able to use my internet provider's account info and use that to get into the internet. it's dial-up, but i'm not paying extra for it.
jinhua wrote:The "Three" network in the UK only lets you look at what they have, on their own site.
Hi
re your comment about using a separate dial up account to access the internet, I tried this approach and entered an ISPs details into connecections in the control panal, however even if I disconnect the "3" GPRS I can't get the phone to perform the dial up when you go into the internet. It asks you which connection to use but if you choose the dial up account to connect with it doesn't do a dial up and just doesn't find the site straight away.
Any idea what I'm doing wrong???
Mick
dipshun wrote:there are two plug-ins installed: Shockwave, and HutchPad Central Plugin.
No sorry, I can't see any options to install other plug ins.
I can't figure out how you can use a dialup connection as my browser won't give me the option of selecting a connection. It automatically goes to the "Three" connection.
packerm wrote:Hi
Mick
I can't even get it to ask me which connection! Where do you get that?
Once you're in the internet (although I hesitate to called 3's cr@p walled garden the internet) goto "Browse" on the menu then "Disconnect". When you then try to go to a web site, e.g. www.bbc.co.uk it will come up and ask you which connection to use in a drop down box. If if you pick a different connection to the 3-gprs one though it doesn't work.
I'm assuming you have also set up the alternative dial up connection? If not this is done via Control Panal, Connections tab, internet accounts.
By the way when I complained to 3 about the walled garden and what I regard as false, or at least mis-leading advertising they said that they planned to review their internet access in the new year whatever that means.
I have also written to BBCs Watchdog about it as I think they shold make it plain on their advertising and web site that you can't access any content outside their own sites. I mean it's a worse service than WAP on a 2G phone!
If anyone else wants to complain go to this link...
http://www.bbc.co.uk/watchdog/contact/
If they get anough complaints perhaps they will get on the case and there's nothing like a little slot on the BBC's consumer program to make them change policy!
Mick
packerm wrote:Once you're in the internet (although I hesitate to called 3's cr@p walled garden the internet) goto "Browse" on the menu then "Disconnect". When you then try to go to a web site, e.g. www.bbc.co.uk it will come up and ask you which connection to use in a drop down box. If if you pick a different connection to the 3-gprs one though it doesn't work.
Mick
Thanks Mick, for your reply.
No, when I disconnect from 3 and try to get another page, I don't get that option. Nothing happens.
It really is a terrible waste of a great phone!
I have been trying to get other browsers that will ask me what connection I want to use, but I can't get one!
Anyway, thanks again and I will certainly be clicking on that link.
