SMS Assistant ver 1.05
2 replies · 2,191 views · Started 04 January 2005
I have just installed SMS Assistant ver 1.05 on my 6670. I wrote in my predetermined message, and set the REPLY TO to ALL (voice calls + text messages), AUTOMATIC DEACTIVATION:OFF, MESSAGE HEADER: OFF. Then I set the program to ACTIVE mode and hide it in the system background.
The weird thing is that the program is only able to auto-reply to incoming SMSs, but not voice calls even though I have the REPLY TO option set to ALL. I tried calling my phone using another phone, and even though my phone had received a lot of missed calls, the program did not initiate any auto-reply actions, since the phone that I used to call my own did not receive any sms on all the missed calls.
Has anyone encounter similar problems? :con? Can anyone offer any remedies? The fireware of my 6670 is V 4.0437ch in case it's of any help.
Thanks.
Sorry I dont know the answer as i dont have the app, but can this application give you the ability to have selected groups/numbers for audible sms alert, so that numbers not submitted will have a silent sms alert?
thanks
