Longer ring?
1 replies · 1,500 views · Started 04 January 2005
Hi ppl
What do i need to do to get my 7610 to ring for longer say 30 secs-1 min before going to answer machine,at the mo it goes after about 10 secs and i keep missing calls.
Thanks in advance
T.
the amount of time it rings is dependant on the network
there are codes you can send to give it a determined number of seconds
Eg. I had codes a few years ago (when O2 was still BTCellNet, so I'm not sure if this still applies😊
**61*+447775040355*10*[nn]#
where the phone number is the network's answer phone number, and nn is the length of ring before the answer phone kicks in between 5 and 30 seconds
other networks will probably have different key sequences, i'm not sure, but definately of course will have a different answer phone number.
Alternatively switch off your answer phone, so it will ring for as long as the person on the other end is prepared to wait.
