Bluetooth Headset
14 replies · 4,971 views · Started 05 January 2005
Which is the best Bluetooth headset that is works flawlessly with the 6630 ? Should I get a Nokia headsets or SonyEricsson ?
I personally use and can recommend the Jabra BT200/250
Has always worked flawlessly on my 3650 / 7610 / 6630
Tried the nokia one - did not like it.
The jabra does not cover your ear - so you can still hear perfectly with it in, and because the mini gell inserts into your ear rather than on your ear the sound is clean crisp and clear when taking calls or listening to music.
Another nice feature - take it out it's cradle and it'll turn itself on and link to the phone, ready to go - put it back on the cradle and it'll disconnect itself from the phone and start charging - all that without a single push of a button.
For me simplicity and functionality like that can not be beaten.
Will
Jabra gets my vote as well (BT250)
Very comfortable, fairly cheap and quite discreet
Battery life is very good. I got mine from CPW.....BT250V and it vibrates which took a while to get used to but it is a great early warning before it starts ringing
alhinai wrote:Which is the best Bluetooth headset that is works flawlessly with the 6630 ? Should I get a Nokia headsets or SonyEricsson ?
iam a very satisfied user of Sony-Ericsson AKONO HBH-300 and its working perfectly,the standby time is the same,as in my device,and i charge them in the same time /once a week/.Its Very comfortable,distance can be 10 meters and the quality and loudness of speech is very good.i can only suggest....
there can be some problem with older models,like HBH-35,and some others from SE,but the HBH-300 is working perfectly,because it supports all the bluetooth profiles /headset,handsfree/. 😉
I am currently using the Nokia HS-4W. It does not work very well. The sound is very low and it sometimes disconnects the link with the handset. :frown:
Hi, I'm using the BT Logitech HS01 headset with the 6600 and the 6630. No problems, no connection loss or whatsoever. Fits most ears like a glove :icon14:
I have the HS-4W form Nokia and it is really terrible, The volume is to low and it disconnects often, dissapointed!
omega
I'm using HDW-3 for my N6600 and 6630,it works well,very clear voice and quick connect.No problem for charging,it has good talk time and worth buying.
Had the HS-4W for 2 days worked fine for a while then started to disconnect and finally didnt work att all (and like others already siad the volume is too low) so i had it changed today fo a Jabra BT800 w000t , i DO recomend it! reaaly nice , well worth every penny lots of cool features......
hi.
have used the siemens hhb-600 with my old phone. it's small, sound quaility is good and it fits quite nicely.
however, i used it twice with my nokia 6630 and both times the volume goes very,very quiet after one minute or so. mic is working fine. very annoying. don't know where the bug is.. hope it helps.
cheers.
hi..ratkat .. i jus wanna know about nokia hdw-3 BT. before i used 6310i with hdw-3 headset it was wonderful. but i brought brand new 6600 .. u know wat the probs.. when i'm connecting to with hdw-3 it's says "Unable to pair with hdw-3".. i dont know why if i'm connecting in 6310i ..it's connecting properly.. please advice if you know any tips jus lemme know..
sundar
Ratkat wrote:I'm Using Nokia HDW-3, works fine no problems
Don't get a SE HBH-35, they will not connect
hi..dhan .. i jus wanna know about nokia hdw-3 BT. before i used 6310i with hdw-3 headset it was wonderful. but i brought brand new 6600 .. u know wat the probs.. when i'm connecting to with hdw-3 it's says "Unable to pair with hdw-3".. i dont know why if i'm connecting in 6310i ..it's connecting properly.. please advice if you know any tips jus lemme know..
sundar
dhan_shh wrote:I'm using HDW-3 for my N6600 and 6630,it works well,very clear voice and quick connect.No problem for charging,it has good talk time and worth buying.
I have N90with bt Type Hs-11W when i detect the device it is detecting correctly but after when i detect the headset it is not paring it is telling tht
## unable to pair hs-11w##
please help me
