i�m very interested in syncing a nokia 9500 with Novell GroupWise. Does anyone else use these two components? Or does anyone know a software that supports the new nokia communicators?
Argon
Argon
Hi Argon
We are also looking for a solution. At present we have installed MS Outlook on the machine that requires syncing and getting it to talk to the GW server. We then use the Nokia PC Suite to sync with Outlook. It works but the Syncing is very slow as it reads ALL Calendar items even if it only has to update 1 or 2 items. We also had trouble with it not wanting to do all data at once. It kept failing when we tried to do too much. eg: 1 year back and 3 years forward. We ended up doing it in small steps of 6-12 months max. It may depend on how much data is there??
We have requested an Eval of "Teamware mobile" but this must run on it's own Linux server. Hope this helps
Cheers
Ian
thanks for your answer. If i understand the "Teamware"-Software, i can�t sync on a local machine. Only via the linux-server. Is this right.?
Did you get the evaluation till now and tested it?
Greets
