Cant Get PC suite to work with Bluetooth
1 replies · 1,786 views · Started 05 January 2005
Hi, before I explain my problem I would like to make it clear that I am no computing noob, I am doing a degree in them, but this has me stumped.
I was trying to follow the readme instructions to set up a com port with the bluetooth dongle. But I think some secrity setting is stopping me, as every time i click the "finish" stage some window apears and disapears as if a security setting is stopping it. Leaving me unable to get the pc suite working. Does anyone know what security setting this is as I cant seem to find where to turn it off. Its getting on my tats. 😡
Cheers :icon14:
Hi, i also had trouble getting PC Suite working with Bluetooth, and what i know is that u must use the newst widcomm drivers for your bluetooth device.
The problem is that this drivers if are not the ones u already have, they wont work with your device without some modifications.
Please see this forum dedicated to this problem, thats where i learn how to make it work:
http://www.jonsguides.com/bt/
Also thre some posts about it on http://forum.gsmhosting.com
Hope this can help you
