i am planning to buy a phone for last 1month and the phone that i am confused with are p910 or p900 or nokia 6630. i am reading lots of views but i am still confused !!!! some say touch screen feature is not that useful or easy and say 6630 is good and some say 6630 is good bcoz of 3g and edge .
and is the any major diff in using p900 and p910 as far as RAm is concerned
can somebody pls help me in deciding wht shld i go for ? right now i am using nokia 3660 and very uncomfortable with limited amout of RAM
plsssssssssssssss help me :frown: [COLOR=Blue]
okay, first off forget the P900. It's between the P910 and 6630 (P910 has more RAM, can take bigger memory cards and has a few fixes like handsfree bluetooth, HTML e-mail etc so don't bother with the P900 unless you can get one really cheap).
After that, the P910 and 6630 are COMPLETELY different devices.
The P910 is a stylus based PDA\Phone with GPRS
The 6630 is designed to be used one handed but will never beat a proper PDA with touchscreen. However, it has 3G.
Do you want a 3G?
Will you use the functions of a proper PDA?
Do you get on with touchscreens?
It's up to you. If you tell us what you intend using it for then we might be able to help. But we can't tell you which is better 'cause they are just different. It's like asking "Which should I buy, a Ferrari Enzo or a Rolls Royce silver ghost?".
