How can I read/tranfer the Sms who are on my Sendo x (By usb) on my PC.
Sendo support says "buy a sim reader".
Which one ? Are there any freeware sim reader program?
Is it not a way to send the sms by IR with FExplorer ?
Thank you for any ideas
Sms reader
i dont know if the x can send its sms to a pc just like that
there r two progs that can do that though
1. desktop manager v1.1>> two parts to the prog, one is installed on ur pc and one on the x. with it u can write sms on ur pc and send it from there (thru ur x) , also u can store the inbox of ur x on ur pc(the prog synchronizes the 2)
2.messagestorer v.1>>> u can convert ur normal sms into a note document and send it to ur pc via bt/infrared(dont know if it works with usb too, dont think it does)
tip> if u do a search in google for ahmmmm not so legal sis progs then u will find somethin for free😉
Thanks for (all) advice.
- Messagestorer v.1 works almost as I need.
- About "desktop manager" there are too many programs with this name. What's the company or any other way to find it.
More thanks...
2. in about it says"desktopmessage-version 1.02. copyright 2003 mobileways.de" hope that helps u in findin it.
Unfortunately desktopmessage seems working with Nokia but not with Sendo X.
Is it a system for making works Nokia apps on Sendo ?
desktopmessage works on my x(german 60c). in "about" it does say "for sep800, nokia 7650 &3650 but it DEFINETLY works on my x
You'll find that most software thats compatible with the 7650 will work on the X
The problem is that when I trie to install the .sis application with Sendo PC connect, I've a message saying
"UIQ20ProductID" is not install. Install it and try again"
So I eve can istall the .sis
What this UIQ... ?
Its a different version of Symbian. You need to download a Symbian 60 version since the Sendo X uses Symbian 6
Wher do I get that ?
Try searching www.handango.com They have alot of software there, but most of it is not free.
And I replace the System on my Sendo ?
which is X1.56.2.2. Realease LG 20 aug 2004.
It's not old...
I don't need to change the firmware on your X to install an application, you need to make sure you've downloaded a Series 60 (1.2) version of DesktopMessage.
A version made of UIQ will not work, since UIQ and Series 60 are not compatible (although they're both based on Symbian OS.
Here's the URL for a version which WILL work on your phone: http://mobileways.de/M/1/1/3/
Thanks. It's working. 😊
sms reader
