i bought N gage QD 3days ago & 2gether with 256mb apacer mmc card. but its always pop up message "unsafe to removed m. card" , so i cant play any game or other application. i know that someone in this forum has the same trouble few days ago, but what is the solution???? anyone can help me?????
POP UP MSG : unsafe to removed...HELP!!!
Ok..either you don't have anygames or you took a card out without Safely removing it
How to remove safely
Press the Power Key
then press "Remove mem. Card"
no, i have several game inside & took out my card using the power key... what i mean is that it just appear frequently...(seems like QD not stable with the mmc card)
Is that my mmc card not compatible with my QD?
i use apacer 256mb, what yours?
i got the same problem...also buy a new one last month,yes...dont use the apacer..it is useless..damn to apacer...it will make your n-gage hang..
walaupun wrote:no, i have several game inside & took out my card using the power key... what i mean is that it just appear frequently...(seems like QD not stable with the mmc card)
i had the same problem as you when i first bought my Qd, as it turned out the mmc card was shit. think the apacer is also the same. the best mmc cards for the ngage are kingston and transcend, i personally use kingston and it works just fine. good luck
