:cry:
I can not open *.nim files with my 9210i
Is there a special player for thoses file?
thanks
David
*.nim video files
The application is called VideoPlayer and is normally installed on your 9210 or at least present on the cdrom.
Thanks, I found it on the CD rom
and it works
hello ! i have a problem with *.nim files.i try to open them with video player and it says: playback error.any ideas?what is happening?what should i do?
Try to unninstall and install again the application.
This should work
