Unusually dead 3650
5 replies · 2,309 views · Started 07 January 2005
Hi all!
Long last since i've been here last time 😊
But now ny 3650 is dead somehow. At power on, the screen lights, the blue nokia text comes up, and it freezes here. (So it's not the turn on-off-on-off problem)
Tried to boot it with all combinations of with/without sim/anothersim/mmc/anothermmc, and holding/not holding the pencil, but nothing difference. Stops at the very beginning, so i can't use the reset code.
Does anybody know ANY way to reset the phone manually, like connecting two dots on the mainboard or something, or get my very last chance is nokia sevice?
f
Kamalayan wrote:Have you tried replacing the batteries? 😉
Yep, but not helped. 😞
It seems to be a sw problem in the os flash in the eeprom, but i cannot get to how to reset it.
My phone had the four blinks problem lately so i had to have it reflashed. Maybe thats the only remedy for your unit as well. Cheers.
So okay, i'm gona take it to the service... 😞
Thanks for the replys, i'm gonna report if the reflash helped.
It should. If it doesnt, they may have to blame some of the hardware parts which will give way to openning your phone and having parts troubleshooted. I prefer the flashing rather than the hardware fixings. Good Luck. :frown:
