Nokia Calendar Sync
0 replies · 10,464 views · Started 07 January 2005
I am having problems syncing the Calendar/Agenda.
Here is the full story.
Originally had a 9210i, 2200 contacts, 2600 Calendar entries.
Used Data Mover to transfer from 9210I -> 9500, no problems.
I can read, write all contacts and calendar entries on the 9500.
I have no connexion problems, Bluetooth and USB Cable both work fine.
I no longer have the 9210i
The syncro works between the PC and the 9500 but only for the Contacts.
I cannot include the Calendar in the syncro, otherwise I get a "SyncML Client jas not responded error".
If I delete the calendar then create a FEW entries no problem I can sync as edbe.
I am currently in the situation whereby I have used Nokias tool for transfering from 9210i -> 9500, so if there is data corruption it has probably been caused by Nokias software.
Nokia does not provide, nor any third party that I have seen, any means by which I can export the Calendar entries.
Does anyone have any idea how I can recuperate the Agenda entries in order that I can put them into Outlook and then retry the Sync from the PC side.
I phoned Nokia but they "advised" me to reformat the Telephone and recreate the
entries by hand. There are 2700 entries dating from 2002, theres no need to point out my disgust at their advice.
Thanks for any help/advice that anyone can offer.
Roy
