Bluetooth Headsets for the Ngage
2 replies · 1,819 views · Started 07 January 2005
Hi all,
I have an Ngage classic and love it. The thing is, it is only really usefull if you have a headset (hands-free-bluetooth). I have one and think it really changed the way I use the telephone. I purchased the Nokia HS-4W wireless head set and it has made the daily use of the Ngage simple and handsfree. The gage stays in a pocket of my jacket and or trousers and I can make calls via voice tag and talk to my hearts desire without having to take out or touch the Gage!
My only problem is that the HS-4W is very quiet, the volume is a bit to low and when driving I have problems sometimes hearing the caller. Does anyone use a different wireless headset? If so, and you are happy with its performance, then please inform me, I am looking to change. I may do a reveiw of the HS-4W if I have time.
thanks, omega
HPJ545 wrote:I have been using the Hello 2 BT headset for almost a week now and I am very happy with it. It is loud enough on both ends and I havent found a game it doesnt work with. It is pretty small and works wonderfuly.
http://www.hello2.com.tw/index.htm
Hope this helps.
Hi , thanks for the tip. The Hello looks very cool. I took the Nokia back and bought the Jabra BT250... Man, what a difference. Get a headset from a firm specializing in headsets!!! The Bt250 is so much more comfortable and the sound is much clearer and louder! I have yet to test the battery but they tout 8 hours and the reviews say they do it .. I am finally in hands free bliss!!!
thanks again for the tips though and have a great one hands free!!! 😃
Ps. Th bt250 is also 30 Euro less....
Omega
